angesom
May 08, 2020Follower
How can i see the Specs of the readynas rn3138
Recently i have purchuased readynas rn3138 and i want to check it's processor speed and also the amount of memory it have but i coundn't find it when i log in with the ip address / admin page. it wou...
May 08, 2020Guru - Experienced User
angesom wrote:
Recently i have purchuased readynas rn3138 and i want to check it's processor speed and also the amount of memory it have but i coundn't find it when i log in with the ip address / admin page. it would be great if you share your ideas
Manuals (and the datasheet) are found here: https://www.netgear.com/support/product/RN3138.aspx#docs
It has 4GB of ECC RAM.
The CPU is described as Intel Atom Quad Core 2.4GHz with QuickAssist in the datasheet.Though there is more precise information saying it is an Intel Atom C2558 here: https://www.netgear.com/business/products/storage/readynas/RN3138.aspx#tab-techspecs
- SandsharkMay 08, 2020Sensei
lscpu.log and mem_info.log in the downloaded log .zip file can be helpful here. They do not show the memory type, though. The only place I know to find that is in the DMI data, readable via SSH if you install dmidecode.
