mangebest's avatar
Feb 25, 2022
how configure Readynas 524X for best video surveillance performance
Hello I have a readynas 524X with four 4TB disks.  I use the readynas surveillance app that i still think is good. I want to ask the community if anyone can tell me how i should configure my ready...
  • StephenB's avatar
    Feb 27, 2022
    mangebest wrote:
    its WD40EFAX  4 TB times 4disks.
    If you are looking for the best performance, the drives are the foundation. Unfortunately the WD40EFAX isn't the best choice for a surveillance application - the WD40EFAX is an SMR drive.  So its sustained write performance is quite poor (and very variable).
    The WD40EFZX (WD Red Plus) is much better for this - it uses CMR technology.
    An Enterprise class drive like the WD4003FFBX (Red Pro) has a faster RPM - which doesn't improve sustained write speed that much over the EFZX, but would improve random access times (which might help when browsing through files for playback).  Enterprise drives do cost more, but they also generally come with 5 year warranties.
ProSupport for Business
