Chessdude's avatar
Chessdude
How do I add a second 10 tb disk on my ReadyNas 214
Hi all. Im planning on adding another 10TB Seagate Ironwolf disk to my ReadyNas 214 as the currently installed similar disk (10TB Seagate Ironwolf)  is almost full. For the benefit of those not famil...
  • StephenB's avatar
    Sep 02, 2020
    Chessdude wrote:
    So does it mean that XRAID will mirror the equivalent of its capacity on the second hard drive.(Please correct me if I'm wrong).
    Yes.  Inserting another 10 TB drive in XRAID mode will result in RAID-1 volume - which is mirrored disks.  Adding a second 10 TB drive in XRAID mode will convert the volume to RAID-5.
    Chessdude wrote:
    So if I switch to FlexRAID, will I lose any data in the first hard drive?
    No.
    Chessdude wrote:
    Does it matter which bay I install the 2nd drive in?
    No.
ProSupport for Business
