mrumsam
Jan 13, 2016Aspirant
How do I change backup alert password for ReadyNAS Replicate #26317585
My boss recently set up ReadyNAS Replicate so that backup alerts are sent to his email address.
We need to change this address but we cannot find where we would do this.
Please help!!
- Jan 13, 2016
Hello mrumsam,
Welcome to the community!
Is that the same email address he uses to login to https://replicate.readynas.com/? If so, then you can modify this at https://remote.readynas.com/, login then click View Profile, this will give you an option to change some info.
mdgm-ntgr
Jan 13, 2016NETGEAR Employee Retired
Your profile indicates you have a 3100 (4-bay legacy rackmount device). Did you incorrectly register your device under the wrong model?
Can you send me your logs (see the Sending Logs link in my sig)?
I should be able to determine from that which model you have.
- BrianL2Jan 13, 2016NETGEAR Employee Retired
Hi mrumsam,
ReadyNAS Replicate is presumably sending e-mail alerts to the e-mail address you registered with replicate.readynas.com. Will it be possible if you could unregister and re-register your account on the admin page under the Cloud tab?
Kind regards,
BrianL
NETGEAR Community Team- mrumsamJan 14, 2016Aspirant
Hi BrianL,
Thanks for your reply.
It look like the email alerts are being sent to the correct email address now. It just took a while to update after I amde the initial change in the Ready Cloud portal.
Re registering was going to be my next step if it didn't work.
Thanks for all yor help.
- JennCJan 14, 2016NETGEAR Employee Retired
Hello mrumsam,
Good to hear it works now.
Feel free to come back if you have something to share or ask as we appreciate each and every contribution to the community. :)
