Unhappy_Custom2
Jul 21, 2016Aspirant
How do I change permissions or disable user shares on ReadyNAS Duo v2?
Technically, I'm not really a new user, as I've owned the device for a few years now. But, I'm in the process of upgrading my drives, via a factory reset, and this is my first time looking at the s...
Hopchen
Jul 21, 2016Prodigy
Hiya,
You shouldn't need to have two versions of RAIDar. The new version 6.x should show a green check-mark on the disk (rather than a green light) if the disk is OK. Does it not show that for you?
Regarding home folders. When you create users then a home folder for that user is automatically created. This home folder is visible only to that user and the admin of the NAS. I believe that you cannot change this setting. I don't remember in OS5 if you can disable the creation of home folders when adding a user. I will check later for you.
Also, note that if you delete a user then the NAS will also delete that user's home folder.
Cheers
