arul999
Sep 17, 2016Aspirant
How do I disable credential auth on the NAS
Newbie question - How do I disable in the settings from not requiring anyone to enter credential to gain access to a shared folder. I read about the "anonymous" setting. However when I select the NAS...
Sep 17, 2016Guru - Experienced User
Is the username you use to log into windows also a username on the NAS?
One thing you can do is put in a credential for the NAS in the Windows Credential Manager. Then Windows uses it automatically.
