BALR1415
Mar 01, 2013Aspirant
how do I read data from a removed Duo V2 disk
I just updated my ReadyNAS Duo V2 to dual 2TB red disks, removing a 1TB Barracuda. It occurred to me that this was a good opportunity to test ReadyNAS data recovery, using the Barracuda. I put the 1TB...
BALR1415
Mar 02, 2013Aspirant
I removed the disk from the USB enclosure and installed it in a PC as the only SATA drive. I then booted the PC with a Knoppix 7 live CD. It did not show up in Knoppix although it was recognized by the BIOS.
My Linux is limited (as are most PC users) so I believe that I must manually mount the disk. So more research.
It seems like getting to data on a disk that has been removed from a ReadyNAS is not as simple as I would have believed.
