BALR1415
Mar 01, 2013Aspirant
how do I read data from a removed Duo V2 disk
I just updated my ReadyNAS Duo V2 to dual 2TB red disks, removing a 1TB Barracuda. It occurred to me that this was a good opportunity to test ReadyNAS data recovery, using the Barracuda. I put the 1TB...
mdgm-ntgr
Mar 28, 2013NETGEAR Employee Retired
The disks in the Duo v2 use the EXT4 filesystem. The process is quite different to what is used for the Duo (v1) units. There is no need for fuseext2 as the Duo v2 uses the standard 4k block size.
You would need to start the RAID using mdadm (you may need to install this via apt-get), do a vgscan, vgchange -ay etc.
