AndrewWykes
Oct 16, 2016Aspirant
How do I tell if it's the Nas or disks that are broken
My 80yo neighbour has a Nas with all his Flac music on. It's not working and I am trying to work out why. A few few years ago I replaced one of the discs successfully. The unit Is on and I ...
Oct 16, 2016Guru - Experienced User
Try install RAIDar on a PC, it should give you some more status information.
http://kb.netgear.com/app/answers/detail/a_id/20684/~/readynas-downloads#raidar
AndrewWykes
Thankyou for replying.
i did that and i says it has a corrupt boot. i can only see this if i have disk 1 in only.
With two disks in it will not start and i cant see it via Raidar. the power light just flashes blue
- mdgm-ntgrOct 16, 2016NETGEAR Employee Retired
Which model shows in RAIDar?
Do you recall which firmware this unit was running?
- AndrewWykesOct 17, 2016Aspirant
Hi
It says Model = ReadyNas Duo, Name = NAS-BA-08-64, Status = Corrupt Root
I would guess the firware is over a year old. I moved away from my neighbour about 8 months ago and it gave it an overhall before this. Not sure the number.
With one disk it has a slow blinking blue and the 2 green leds are flashing 3 times slow and then 3 times quick.
Thanks
Thenone disc thats in has a green tick on the Radiar screen
- StephenBOct 17, 2016Guru - Experienced User
Did you try booting with disk 2 only (in slot 2)? Make sure you have the NAS powered down when you remove/reinsert these disks.
- AndrewWykesOct 18, 2016Aspirant
Disc 2 only results in slow flashing blue light with no green leds and not able to see via Raidar.
Thanks again for for all the help.
- StephenBOct 18, 2016Guru - Experienced User
The next step is to shutdown the NAS and remove both drives (label them).
Then
(a) power up the NAS and confirm that RAIDar sees a "no disks" status
(b) test both disks with vendor tools in a windows PC (seatools for seagate, lifeguard for western digital).
If the NAS hasn't been monitored reqularly, it is possible that both disks have failed.
