Morob118two
Jan 30, 2017Follower
how do I use bonded NICs for backups to ReadyNAS?
Hi total noob. so apologies.. I have a readynas box where the admin IP is 192.168.100.50 1GB, the bonded (2x10Gbe) NICs are on 192.168.100.48,teaming mode 802.3ad, lacp. using Unitrends S/w to bac...
Jan 31, 2017Guru - Experienced User
Morob118two wrote:
how do I select this bond as the default IP for the backup? I know it's a very noob question.can you explicitly make nfs or iscsi go over this bond? obviously I dont want to use the mgmt ip of .50 it is too slow.
Actually it's an excellent question.
When you are backing up to the NAS, all you need to do is specify the IP address for the bond (192.168.100.48). That will direct all the traffic going into the NAS to use the teamed interface. If you want to use hostnames, you can of course create different DNS names for the two addresses.
In the other direction you have much less control. The NAS could choose to send traffic over 192.168.100.50 and there isn't much you can do about it. The needed linux tools aren't built into the NAS (and you'd need to implement that kind of routing with ssh, since there's no support for it in the web ui).
You could create a vlan (with your switches), and shift the management plane into a different IP address space (walled off from the main network). That would keep data traffic off the management interface. That might complicate your overall management though.
- brianccramerJun 20, 2017Aspirant
Couldnt you do something with the Routes in networking?
- StephenBJun 20, 2017Guru - Experienced User
If the admins also use storage on the NAS it might get pretty difficult.
