Morob118two
Jan 30, 2017Follower
how do I use bonded NICs for backups to ReadyNAS?
Hi total noob. so apologies.. I have a readynas box where the admin IP is 192.168.100.50 1GB, the bonded (2x10Gbe) NICs are on 192.168.100.48,teaming mode 802.3ad, lacp. using Unitrends S/w to bac...
TeknoJnky
Jun 20, 2017Hero
your simplest solution is to access the admin interface via the bond ip and unplug the gbit link.
alternatively you can put the admin link on a different subnet, you don't necessarily need a dedicated vlan.
IE put admin on 10.x.x.x or 192.168.200.50, of course then you would need to use a computer with an ip also in this admin range (or use internal routes or vlans on your network).
