Madmax1963
Mar 09, 2016Aspirant
How I solved my ReadyCloud problem after switching from DCHP to static IP
Today I changed my IP from DHCP to a static IP and as soon as I did that my NAS disappeared from ReadyCloud. After reading a few threads about people having the same problems I had I took the fallowi...
- Mar 10, 2016
Hi,
I had this UI bug addressed in 6.5.0.
Previously, when you switched from DHCP to static, we would show you the DHCP DNS IP address even when on static. When you saved and went back into the adapter, you would not see any DNS servers. Now in 6.5.0, we will display you the "Static DNS IP config" when on Static, and the "DHCP DNS IP config" when using DHCP...
This is actually a common problem that 6.5.0 should help fix (by allowing you to acknowledge there are no DNS servers when switching to static). Everyone who switched before hand will still need to go in and manually put in a DNS server.
kohdee
Mar 10, 2016NETGEAR Expert
Hi,
- Madmax1963Mar 10, 2016Aspirant
That is certainly great news to hear, since the way it is now can be a bit confusing...excellent !!!!!
MadMax1963
