stfarm
Apr 02, 2021Aspirant
How to add ExpressVPN (or any other) on the ReadyNAS 6.10.4
Hello everybody, I am sorry if this has been asked already. I want to use my current VPN express on my ReadyNAS. How can I do this please? If VPN Express is not support, any other would be fin...
Apr 02, 2021Guru - Experienced User
Is your goal remote access? Or something else?
stfarm
Apr 04, 2021Aspirant
To run qBitTorrent
- SandsharkApr 04, 2021Sensei
if by "VPN Express" you really mean ExpressVPN, then they do have a Linux version, but they don't list the requirements for running it. You'll have to ask them if it will run on Debian Jessie, and you'll have to install it via SSH if it does. If their system can be used with OpenVPN (many can), then there is a version of it that works with the ReadyNAS.
