dishmagic66
Apr 26, 2014Guide
How to control fanspeed on a RN104
On special request, here is a workaround for controling the fanspeed of the RN104 ( most likely the same on a 102). For this you will have to SSH in to the NAS. Thanks to Moseleypj for doing the ...
tiff_lee
May 23, 2015Tutor
Finally cracked it! after some googling I found out how to create the files directly via the terminal window rather than using notepad++ and copying them over via STFP, it seems copying the code into notepad++ was causing some unknown errors.
