darkone
Jun 08, 2017Guide
How to control fanspeed on a RN104 for 6.7.4
Updating an old script to control the fan speed on the newer Firmware. I am not claiming credit all i did was update the sys path for the new frimware and change the startup script that had a typo
originally came from post https://community.netgear.com/t5/New-to-ReadyNAS/How-to-control-fanspeed-on-a-RN104/td-p/911970
1. First you create a file in /root with the name fanoverride.sh. Put the following lines in to the file.
nano /root/fanoverride.sh
#!/bin/bash
## Variables ##
FANPWMPATH=/sys/devices/platform/soc/soc:internal-regs/d0011000.i2c/i2c-0/0-003e/hwmon/hwmon0/fan1_target
FANSPEEDPATH=/sys/devices/platform/soc/soc:internal-regs/d0011000.i2c/i2c-0/0-003e/hwmon/hwmon0/fan1_input
CORETEMPPATH=/sys/devices/virtual/thermal/thermal_zone0/temp
MAXFAN=3500 # Maximum operable speed
MINFAN=700 # Minimum operable speed
MINTEMP=35000 #35 C
MAXTEMP=70000 #70 C
NEWSPEED=1000 # Initial fan speed (%)
## Functions ##
function getReadings {
FANPWM=$(cat $FANPWMPATH)
FANSPEED=$(cat $FANSPEEDPATH)
CORETEMP=$(cat $CORETEMPPATH)
function setFanSpeed {
TEMPFAN=$(expr $MAXFAN - $MINFAN)
NEWFAN=$(expr $TEMPFAN \* $NEWSPEED)
NEWFAN=$(expr $NEWFAN / 100)
NEWFAN=$(expr $NEWFAN + $MINFAN)
if [ $NEWFAN -lt $MINFAN ]; then
NEWFAN=$MINFAN
fi
if [ $NEWFAN -gt $MAXFAN ]; then
NEWFAN=$MAXFAN
fi
echo New Speed: $NEWFAN RPM
echo $NEWFAN > $FANPWMPATH
function calcFanPercent {
TEMPRAN=$(expr $MAXTEMP - $MINTEMP)
TEMPREL=$(expr $CORETEMP - $MINTEMP)
TEMPREL=$(expr $TEMPREL \* 100)
TEMPPER=$(expr $TEMPREL / $TEMPRAN)
NEWSPEED=$TEMPPER
echo New Speed Set: $NEWSPEED % at $(date +%T)
echo "Automatically controlling fan speed..."
while true
do
getReadings
echo "Temp: $CORETEMP C FAN: $NEWSPEED% [$FANSPEED RPM] [PWM $FANPWM]"
calcFanPercent
setFanSpeed
sleep 5
done
###################################################################2. Now chmod 755 /root/fanoverride.sh
3. Now create a file in /etc/init.d with the name fanoveride.
nano /etc/init.d/fanoverride
#!/bin/sh
### BEGIN INIT INFO
# Provides: FanOveride
# Required-Start: $local_fs $network $named $time $syslog
# Required-Stop: $local_fs $network $named $time $syslog
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Description: FanOveride overides the default ReadyNAS fan control
### END INIT INFO
SCRIPT=/root/fanoverride.sh
RUNAS=root
PIDFILE=/var/run/fanoveride.pid
LOGFILE=/var/log/fanoveride.log
start() {
if [ -f /var/run/$PIDNAME ] && kill -0 $(cat /var/run/$PIDNAME); then
echo 'Service already running' >&2
return 1
fi
echo 'Starting service.' >&2
local CMD="$SCRIPT &> \"$LOGFILE\" & echo \$!"
su -c "$CMD" $RUNAS > "$PIDFILE"
echo 'Service started' >&2
stop() {
if [ ! -f "$PIDFILE" ] || ! kill -0 $(cat "$PIDFILE"); then
echo 'Service not running' >&2
return 1
fi
echo 'Stopping service.' >&2
kill -15 $(cat "$PIDFILE") && rm -f "$PIDFILE"
echo 'Service stopped' >&2
uninstall() {
echo -n "Are you really sure you want to uninstall this service? That cannot be undone. [yes|No] "
local SURE
read SURE
if [ "$SURE" = "yes" ]; then
stop
rm -f "$PIDFILE"
echo "Notice: log file is not be removed: '$LOGFILE'" >&2
update-rc.d -f <NAME> remove
rm -fv "$0"
fi
case "$1" in
start)
start
stop)
stop
uninstall)
uninstall
restart)
stop
start
echo "Usage: $0 {start|stop|restart|uninstall}"
esac4. Now make sure it is executable
chmod +755 /etc/init.d/fanoverride
5. Make it start at boot or start it manually
#auto start with system update-rc.d fanoverride defaults #manually service fanoverride start service fanoverride stop
Use at you own risk and its not my fault if you break your NAS or burn your house down :smileyhappy:.
Post if you have questions
- mdgm-ntgrNETGEAR Employee Retired
Not sure why you'd want to use this with the range of in-built fan control options available now.
- darkoneGuide
Well the build in method thur the GUI even on the cool setting doesn't seem to keep the NAS cool at all max i have seen 800-1000 RPMs. With CPU temp at 60 C. At least with this script you can get temps down to 50 C and HD temp will be lower as well.
I feel Netgear needs a better calc for fan speed or at least more control to the user. aka thermal limits based on temps like QNAP and almost every other vendor
Also i do feel like this script should only be used by people that really know what they are doing. Since it is basicly a hack job and will most likely break when 6.8 or later rolls out
- Retired_Member
When my rn104 gets challenged its fan goes up to 3k+ rpm. That keeps the cpu below 60C and the 4 HGSTs in the 40s.
This is good enough for my purposes, because it is getting difficult to ignore the noise created by this level of cooling.
I never saw the fan going beyond 4k rpm and do not look forward to experiencing that. I imagine to hear such a level of noise, which could hardly be ignored in a living room.
I'm always using cooling option "balanced" and sometimes set that to "cool", if any kind of "purgatory" is in sight.
I live in Singapore and the auto fan control setting still don't keep the disks at acceptable temps, so this is useful. I don't want to wait until the disk hit 50+ degress for the fan to ramp up
I'm getting 'Failed to start fanoverride.service: Unit fanoverride.service not found.'
any pointers?
- michtuTutor
But, why don't install fancotrol from Debian repo?
- darkoneGuide
Idk Never tried it on an ARM based system. I guess it would work if 104 uses a Lm-sensors to control the fan. My guess it might mess up the frontend gui. but idk
Have you used it? and if so any issues?
- michtuTutor
You can have right.
I don't test it - I have different model ;)
But fancontrol has tool for generation config and it can detect sensors on the motherboard.
