dishmagic66
Apr 26, 2014Guide
How to control fanspeed on a RN104
On special request, here is a workaround for controling the fanspeed of the RN104 ( most likely the same on a 102).
For this you will have to SSH in to the NAS.
Thanks to Moseleypj for doing the work.
First you create a file in /root with the name fanoveride. Put the following lines in to the file.
Now chmod 755 /root/fanoveride
Now create a file in /etc/init.d with the name fanoveride.
Put the following lines in to this script
Now make sure it is executable and starts on boot:
To control it manually:
In my case i have the min and max temp in the script set to 35 and 75 degrees to create a nice fan response wich is not to nervous.
If you set it between 40 and 65 the regulating becomes more agressive.
Just play with the values for your needs.
#!/bin/bash
## Variables ##
FANPWMPATH=/sys/devices/platform/mv64xxx_i2c.0/i2c-0/0-003e/pwm1
FANSPEEDPATH=/sys/devices/platform/mv64xxx_i2c.0/i2c-0/0-003e/fan1_input
CORETEMPPATH=/sys/devices/platform/axp-temp.0/temp1_input
MAXFAN=100 # Maximum operable speed
MINFAN=0 # Minimum operable speed
MINPWM=75 # PWM Limit
MAXPWM=255 # PWM Limit
MINTEMP=35 # Min temp -> Fan slowest
MAXTEMP=75 # Max temp -> Fan fastest
NEWSPEED=50 # Initial fan speed (%)
## Functions ##
function getReadings {
FANPWM=$(cat $FANPWMPATH)
FANSPEED=$(cat $FANSPEEDPATH)
CORETEMP=$(cat $CORETEMPPATH)
function setFanSpeed {
if [ $NEWSPEED -lt $MINFAN ]; then
NEWSPEED=$MINFAN
fi
if [ $NEWSPEED -gt $MAXFAN ]; then
NEWSPEED=$MAXFAN
fi
NEWPWM=$(expr $MAXPWM - $MINPWM)
NEWPWM=$(expr $NEWPWM \* $NEWSPEED)
NEWPWM=$(expr $NEWPWM / 100)
NEWPWM=$(expr $NEWPWM + $MINPWM)
echo $NEWPWM > /sys/devices/platform/mv64xxx_i2c.0/i2c-0/0-003e/pwm1
function calcFanPercent {
TEMPRAN=$(expr $MAXTEMP - $MINTEMP)
TEMPREL=$(expr $CORETEMP - $MINTEMP)
TEMPREL=$(expr $TEMPREL \* 100)
TEMPPER=$(expr $TEMPREL / $TEMPRAN)
NEWSPEED=$TEMPPER
echo "Automatically controlling fan speed..."
while true
do
getReadings
echo "Temp: $CORETEMP C FAN: $NEWSPEED% [$FANSPEED RPM] [$FANPWM]"
calcFanPercent
setFanSpeed
sleep 10
done
#!/bin/sh
### BEGIN INIT INFO
# Provides: FanOveride
# Required-Start: $local_fs $network $named $time $syslog
# Required-Stop: $local_fs $network $named $time $syslog
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Description: FanOveride overides the default ReadyNAS fan control
### END INIT INFO
SCRIPT=~/fanoveride
RUNAS=root
PIDFILE=/var/run/fanoveride.pid
LOGFILE=/var/log/fanoveride.log
start() {
if [ -f /var/run/$PIDNAME ] && kill -0 $(cat /var/run/$PIDNAME); then
echo 'Service already running' >&2
return 1
fi
echo 'Starting service.' >&2
local CMD="$SCRIPT &> \"$LOGFILE\" & echo \$!"
su -c "$CMD" $RUNAS > "$PIDFILE"
echo 'Service started' >&2
stop() {
if [ ! -f "$PIDFILE" ] || ! kill -0 $(cat "$PIDFILE"); then
echo 'Service not running' >&2
return 1
fi
echo 'Stopping service.' >&2
kill -15 $(cat "$PIDFILE") && rm -f "$PIDFILE"
echo 'Service stopped' >&2
uninstall() {
echo -n "Are you really sure you want to uninstall this service? That cannot be undone. [yes|No] "
local SURE
read SURE
if [ "$SURE" = "yes" ]; then
stop
rm -f "$PIDFILE"
echo "Notice: log file is not be removed: '$LOGFILE'" >&2
update-rc.d -f <NAME> remove
rm -fv "$0"
fi
case "$1" in
start)
start
stop)
stop
uninstall)
uninstall
retart)
stop
start
echo "Usage: $0 {start|stop|restart|uninstall}"
esac
chmod +755 /etc/init.d/fanoveride
update-rc.d fanoveride defaults
service fanoveride start
service fanoveride stop
- gareth_iowcAspirant:P you sir are a legend! my fan speed would never jump above 800rpm before. cpu used to sit around 70oc and lost 2 drives due to heat.
installed your script and the fan is actually doing some work.
can't thank you enough - Just curious....
What is your environment temperature and at what are your new average values for disc temp, cpu temp and at what revs is the fan running now? - gareth_iowcAspirantI've set the range 35-65oc room temperature is around 17oc. Fan speed sits around 1300-1500 and I've seen a drop from 55oc on the drives to 37-39 and 70 to 50 on the cpu.
- saketbAspirantHi,
This is a great way to control the fan speed of the NAS 104 and to bring down the temps which is always high.
I would like to ask, whether does it effect the FAN in anyway, I mean is the FAN meant to run above the current spinning speeds. Or what is the maximum RPM the FAN can spin on RN104?
My fan spins at 700-850 RPM with CPU Temp @ 65-70 C & HDD's @ 45-50 C.
I have already exchanged (under warranty) my NAS in which the FAN was dead after 6 months of purchase. So, was worried if anything goes wrong.
Kindly reply to this as, I am very much eager to get the temps of cpu and hdd's down from those levels. - gareth_iowcAspirantThe fan is easily within it's limits. They are capable of doing high 4k rpm safely.
I very much recommend getting the drive temps down.
I also think net gear should rethink their thermal management - townsmcpAspirantHi all
Looking for a bit of help. I have an RN104 NAS, have created the 2 files listed in the first post, set them to 775, done the update-rc.d and when I try running fanoveride I get the following:
root@JTS104:~# service fanoveride start
env: /etc/init.d/fanoveride: No such file or directory
Any suggestions?
Thanks in advance - enter the full path:
/etc/init.d/fanoveride start - townsmcpAspirantThanks - just tried that and now getting:
root@JTS104:/etc/init.d# service /etc/init.d/fanoveride start
/etc/init.d/fanoveride: unrecognized service
I am running OS 6.1.8
Just to confirm, does it matter that I created the above files in Windows Notepad (win 7) and then SFTP the files in place (hehe and I did remove the .txt extension before copying over)?
Also, when I do the update-rc bit I see the following:root@JTS104:/etc/init.d# update-rc.d fanoveride defaults
update-rc.d: using dependency based boot sequencing
insserv: warning: script 'istat' missing LSB tags and overrides
That shouldnt be a problem should it?
thanks - Most likely that Notepad is the cause. You should use a Linux compatible editor, like ultraedit or something like that, or edit on the nas self using "vi"
Option 2:
I am not shure if dos2unix is present on the nas, if so then you can try: dos2unix fanoveride. Do this for both files. Or make new files :) - StephenBGuru - Experienced UserI agree that the mismatch between linux and windows end-of-line conventions is the likely cause.
notepad++ is a free PC download which also is compatible with linux (http://notepad-plus-plus.org/)
