dishmagic66
Apr 26, 2014Guide
How to control fanspeed on a RN104
On special request, here is a workaround for controling the fanspeed of the RN104 ( most likely the same on a 102). For this you will have to SSH in to the NAS. Thanks to Moseleypj for doing the ...
saketb
May 30, 2014Aspirant
Hi,
This is a great way to control the fan speed of the NAS 104 and to bring down the temps which is always high.
I would like to ask, whether does it effect the FAN in anyway, I mean is the FAN meant to run above the current spinning speeds. Or what is the maximum RPM the FAN can spin on RN104?
My fan spins at 700-850 RPM with CPU Temp @ 65-70 C & HDD's @ 45-50 C.
I have already exchanged (under warranty) my NAS in which the FAN was dead after 6 months of purchase. So, was worried if anything goes wrong.
Kindly reply to this as, I am very much eager to get the temps of cpu and hdd's down from those levels.
