dishmagic66
Apr 26, 2014Guide
How to control fanspeed on a RN104
On special request, here is a workaround for controling the fanspeed of the RN104 ( most likely the same on a 102). For this you will have to SSH in to the NAS. Thanks to Moseleypj for doing the ...
dishmagic66
May 30, 2014Guide
Most likely that Notepad is the cause. You should use a Linux compatible editor, like ultraedit or something like that, or edit on the nas self using "vi"
Option 2:
I am not shure if dos2unix is present on the nas, if so then you can try: dos2unix fanoveride. Do this for both files. Or make new files :)
Option 2:
