dishmagic66
Apr 26, 2014Guide
How to control fanspeed on a RN104
On special request, here is a workaround for controling the fanspeed of the RN104 ( most likely the same on a 102). For this you will have to SSH in to the NAS. Thanks to Moseleypj for doing the ...
gareth_iowc
May 19, 2014Aspirant
:P you sir are a legend! my fan speed would never jump above 800rpm before. cpu used to sit around 70oc and lost 2 drives due to heat.
installed your script and the fan is actually doing some work.
can't thank you enough
