dishmagic66
Apr 26, 2014Guide
How to control fanspeed on a RN104
On special request, here is a workaround for controling the fanspeed of the RN104 ( most likely the same on a 102). For this you will have to SSH in to the NAS. Thanks to Moseleypj for doing the ...
townsmcp
May 30, 2014Aspirant
Thanks - just tried that and now getting:
I am running OS 6.1.8
Just to confirm, does it matter that I created the above files in Windows Notepad (win 7) and then SFTP the files in place (hehe and I did remove the .txt extension before copying over)?
Also, when I do the update-rc bit I see the following:
That shouldnt be a problem should it?
thanks
root@JTS104:/etc/init.d# service /etc/init.d/fanoveride start
/etc/init.d/fanoveride: unrecognized service
root@JTS104:/etc/init.d# update-rc.d fanoveride defaults
update-rc.d: using dependency based boot sequencing
insserv: warning: script 'istat' missing LSB tags and overrides
thanks
