dishmagic66
Apr 26, 2014Guide
How to control fanspeed on a RN104
On special request, here is a workaround for controling the fanspeed of the RN104 ( most likely the same on a 102). For this you will have to SSH in to the NAS. Thanks to Moseleypj for doing the ...
gareth_iowc
May 20, 2014Aspirant
I've set the range 35-65oc room temperature is around 17oc. Fan speed sits around 1300-1500 and I've seen a drop from 55oc on the drives to 37-39 and 70 to 50 on the cpu.
