dishmagic66
Apr 26, 2014Guide
How to control fanspeed on a RN104
On special request, here is a workaround for controling the fanspeed of the RN104 ( most likely the same on a 102). For this you will have to SSH in to the NAS. Thanks to Moseleypj for doing the ...
May 30, 2014Guru - Experienced User
I agree that the mismatch between linux and windows end-of-line conventions is the likely cause.
notepad++ is a free PC download which also is compatible with linux (http://notepad-plus-plus.org/)
