dishmagic66's avatar
Apr 26, 2014
How to control fanspeed on a RN104
On special request, here is a workaround for controling the fanspeed of the RN104 ( most likely the same on a 102).
For this you will have to SSH in to the NAS.
Thanks to Moseleypj for doing the work.
First you create a file in /root with the name fanoveride. Put the following lines in to the file.
    #!/bin/bash
## Variables ##
FANPWMPATH=/sys/devices/platform/mv64xxx_i2c.0/i2c-0/0-003e/pwm1
FANSPEEDPATH=/sys/devices/platform/mv64xxx_i2c.0/i2c-0/0-003e/fan1_input
CORETEMPPATH=/sys/devices/platform/axp-temp.0/temp1_input
MAXFAN=100 # Maximum operable speed
MINFAN=0 # Minimum operable speed
MINPWM=75 # PWM Limit
MAXPWM=255 # PWM Limit
MINTEMP=35 # Min temp -> Fan slowest
MAXTEMP=75 # Max temp -> Fan fastest
NEWSPEED=50 # Initial fan speed (%)
## Functions ##
function getReadings {
FANPWM=$(cat $FANPWMPATH)
FANSPEED=$(cat $FANSPEEDPATH)
CORETEMP=$(cat $CORETEMPPATH)
function setFanSpeed {
if [ $NEWSPEED -lt $MINFAN ]; then
NEWSPEED=$MINFAN
fi
if [ $NEWSPEED -gt $MAXFAN ]; then
NEWSPEED=$MAXFAN
fi
NEWPWM=$(expr $MAXPWM - $MINPWM)
NEWPWM=$(expr $NEWPWM \* $NEWSPEED)
NEWPWM=$(expr $NEWPWM / 100)
NEWPWM=$(expr $NEWPWM + $MINPWM)
echo $NEWPWM > /sys/devices/platform/mv64xxx_i2c.0/i2c-0/0-003e/pwm1
function calcFanPercent {
TEMPRAN=$(expr $MAXTEMP - $MINTEMP)
TEMPREL=$(expr $CORETEMP - $MINTEMP)
TEMPREL=$(expr $TEMPREL \* 100)
TEMPPER=$(expr $TEMPREL / $TEMPRAN)
NEWSPEED=$TEMPPER
echo "Automatically controlling fan speed..."
while true
do
getReadings
echo "Temp: $CORETEMP C FAN: $NEWSPEED% [$FANSPEED RPM] [$FANPWM]"
calcFanPercent
setFanSpeed
sleep 10
done
Now chmod 755 /root/fanoveride
Now create a file in /etc/init.d with the name fanoveride.
Put the following lines in to this script
#!/bin/sh
### BEGIN INIT INFO
# Provides: FanOveride
# Required-Start: $local_fs $network $named $time $syslog
# Required-Stop: $local_fs $network $named $time $syslog
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Description: FanOveride overides the default ReadyNAS fan control
### END INIT INFO
SCRIPT=~/fanoveride
RUNAS=root
PIDFILE=/var/run/fanoveride.pid
LOGFILE=/var/log/fanoveride.log
start() {
if [ -f /var/run/$PIDNAME ] && kill -0 $(cat /var/run/$PIDNAME); then
echo 'Service already running' >&2
return 1
fi
echo 'Starting service.' >&2
local CMD="$SCRIPT &> \"$LOGFILE\" & echo \$!"
su -c "$CMD" $RUNAS > "$PIDFILE"
echo 'Service started' >&2
stop() {
if [ ! -f "$PIDFILE" ] || ! kill -0 $(cat "$PIDFILE"); then
echo 'Service not running' >&2
return 1
fi
echo 'Stopping service.' >&2
kill -15 $(cat "$PIDFILE") && rm -f "$PIDFILE"
echo 'Service stopped' >&2
uninstall() {
echo -n "Are you really sure you want to uninstall this service? That cannot be undone. [yes|No] "
local SURE
read SURE
if [ "$SURE" = "yes" ]; then
stop
rm -f "$PIDFILE"
echo "Notice: log file is not be removed: '$LOGFILE'" >&2
update-rc.d -f <NAME> remove
rm -fv "$0"
fi
case "$1" in
start)
start
stop)
stop
uninstall)
uninstall
retart)
stop
start
echo "Usage: $0 {start|stop|restart|uninstall}"
esac
Now make sure it is executable and starts on boot:
chmod +755 /etc/init.d/fanoveride
update-rc.d fanoveride defaults
To control it manually:
service fanoveride start
service fanoveride stop
In my case i have the min and max temp in the script set to 35 and 75 degrees to create a nice fan response wich is not to nervous.
If you set it between 40 and 65 the regulating becomes more agressive.
Just play with the values for your needs.
ProSupport for Business
