darkone
Jun 08, 2017Guide
How to control fanspeed on a RN104 for 6.7.4
Updating an old script to control the fan speed on the newer Firmware. I am not claiming credit all i did was update the sys path for the new frimware and change the startup script that had a typo ...
darkone
Aug 29, 2017Guide
Idk Never tried it on an ARM based system. I guess it would work if 104 uses a Lm-sensors to control the fan. My guess it might mess up the frontend gui. but idk
Have you used it? and if so any issues?
michtu
Sep 07, 2017Tutor
You can have right.
I don't test it - I have different model ;)
But fancontrol has tool for generation config and it can detect sensors on the motherboard.
- AndreasK123Sep 20, 2017Guide
i'm willing to give this a go on my 314. just worried that it won't detect the sensors properly
