darkone
Jun 08, 2017Guide
How to control fanspeed on a RN104 for 6.7.4
Updating an old script to control the fan speed on the newer Firmware. I am not claiming credit all i did was update the sys path for the new frimware and change the startup script that had a typo ...
michtu
Aug 29, 2017Tutor
But, why don't install fancotrol from Debian repo?
darkone
Aug 29, 2017Guide
Idk Never tried it on an ARM based system. I guess it would work if 104 uses a Lm-sensors to control the fan. My guess it might mess up the frontend gui. but idk
Have you used it? and if so any issues?
- michtuSep 07, 2017Tutor
You can have right.
I don't test it - I have different model ;)
But fancontrol has tool for generation config and it can detect sensors on the motherboard.
- AndreasK123Sep 20, 2017Guide
i'm willing to give this a go on my 314. just worried that it won't detect the sensors properly
