ZeroGravityWeb
Aug 20, 2015Aspirant
How to create a user with admin rights to a share
I have a ReadyNAS 104 that is storing recordings for Axis Camera Station. Apparently I need a user with admin rights to the share (not just read/write) for it to be able to delete old recordings. I c...
ZeroGravityWeb
It is confusing me. The axis system indicates there is storage outside the system that is taking up space. The only data on the drive is the Axis video recordings. The Axis system is set to delete old recordings after 15 days. There are recordings back to March still on the share. It appears that old recordings are not being deleted. If this was the totally the case then the drive would quickly fill up and remain full but the system keeps recording which indicates that something must be being deleted somewhere. Hence my confusion.
I changed the settings as you indicated.
- I have created a user via ReadyNas with the same user name (J-PC) and password from the windows 7 PC that has the Axis recording service running.
- I created a group "Axis" and assigned this to be the primary group of the user (J-PC)
- I went to the settings for the share. SMB is the only protocol I have enabled.
- Under Network Access I have: Everyone: RO; admin R/W; Axis: R/W; users: no setting; J-PC: R/W; Allow anonymous access checked.
- Under File Access: File Owner: J-PC; Folder Group: Axis; Everyone: no setting; Folder Owner: R/W; Folder Group: R/W; Axis: R/W; users: RO; guest: RO; J-PC: R/W;
When I uncheck Allow anonymous access I get a message from Axis Camera Station saying Access to disk has been denied.
Have I setup the user correctly? What am I missing? Do I need to let it run for a while to see if the new settings have changed something? I would like to remove anonymous access.
Thanks Again
vandermerwe
Aug 20, 2015Master
I would start by allowing R/W access to admin, everyone, users, Axis, and J-PC and unticking allow anonymous access. Does that work?
As part of figuring this out, what happens if you make the windows user the same as your readynas admin credentials ie admin/password?
