Sanyiapilota
Dec 19, 2019Aspirant
how to free up space without deleting snapshots
Hi! I have a Readynas 102 with OS "Version 6.10.2" running on it. 2 x 2TB disks redundant with Raid 1 (X-Raid enabled) (screen attached), snapshots on with 6 years of protection. I recently no...
Sanyiapilota
Dec 21, 2019Aspirant
Thanks for the fast answer.
Sorry for "backup" expression, i meant the mirror disc as you understood it good. :)
Backup is not a problem, i also have daily backups to another (older) nas.
I used to have the quota checkbox checked, now i turned it off, and also balanced the disks but no more space available then.
I don't understand that how can't i see the used space for snapshots, just the "available space and used space" unless i deleted 30% of the used space by those raw videos. Those should be only in the "snapshots".
But i see the same "1,2TB" used and no space indicated for snapshots as before deleting those.
Dec 21, 2019Guru - Experienced User
You can't see the used space for snapshots because you turned off quota. So turn that back on.
- SanyiapilotaDec 21, 2019Aspirant
I turned it on again yesterday and still nothing.
Printscreen attached, and that's the all shares what i have, take a look at it.- StephenBDec 22, 2019Guru - Experienced User
Printscreen attached, and that's the all shares what i have, take a look at it.Normally you should see snapshot consumption (both total and for each share) if quota is enabled on the volume tab.
If you still aren't, then try rebooting the NAS.
- SanyiapilotaDec 22, 2019Aspirant
Thanks but still nothing.
Reboot and balance done, and still the same as the picture. Firmware is the latest too.
Any idea?
