timhood
Jul 24, 2024Star
How to get volume back to read-write mode
I have a ReadyNAS 428 with two RAID5 Flex-RAID volumes. One volume experienced a disk failure and the volume was changed to read-only. I replaced the disk, formatted it, added it to the volume, and w...
- Jul 25, 2024
I had that happen to me. In my case, I knew it was because my EDA500 came unplugged during a write operation, and it was fixed. But everything I tried to make it read/write would not "take" -- it went back to read-only. It sounds like you already have a backup, which is good. Just make sure it's up to date and destroy and re-create the volume. I wouldn't trust the volume to not have a hidden remaining issue if you do anything else. The NAS makes the volume read-only to keep you from doing something that may destroy it but give you a chance to back it up. Take the hint.
timhood
Aug 02, 2024Star
I don't have much experience here, and I couldn't find anything I could do (even via SSH) to put the volume back into R/W mode, but I thought of another possibility. Do you have the ability to add another drive to the volume, even if just temporarily? That should open up free space and in theory, it should allow read/write again.
tijgert
Aug 02, 2024Guide
Alas no, I have only 16TB drives (6x) and all bays are populated. I would have to buy an 18TB drive just to test that and even then I couldn't say if it would add to the space as it's RAID5 in X-Raid. If someone could conform that I might do that, but it'd be a real bummer if it just uses 16TB of the 18TB and keeps complaining.
Super annoying as it says it has 1.28GB free space.. Just how much does it need to go back to R/W??
Would a defrag, balance or scrub possibly free up some space?
Afraid to try without an expert telling me to do so.
I would try deleting files through SSH, but I can't find a way to see them. SSH noob..
- SandsharkAug 02, 2024Sensei
tijgert , to add space, you'll need at least two larger drives. But now that the damage is done to the volume, more space won't fix the problem. It will never put itself back in read/write mode and when I tried to force it via SSH (which you've already said you have no familiarity with), nothing "took". Since you have a current backup, you just need to bite the bullet and destroy the volume, re-create it, and restore files from your backup. Every time you re-boot, you risk losing the volume completely, and thus having to delete it or even do a full factory default.
If you are going to add space, the time to do it is after you delete the volume and before you re-create it. That way, there will be only one re-sync except the short ones for the OS and swap partitions that occur when you swap a drive. I would certainly go with something bigger than 18TB. Assuming you do swap out only two, the new RAID group will be RAID1, so you will only see half of the additional space. Two 18TB drives are a big expense for a 2TB increase in size.
A couple notes for you both: If you are saving and restoring a configuration to get the shares and permissions the same, the new volume must have the same name as the old one. If the volume is the primary (or only) one, it will contain home folders. If you have two volumes, it will create new home folders on the other one and designate it as primary when you destroy the other one. But, it doesn't move the contents. If it is your only volume, then restoring a configuration will not create home folders That's normally done when the user first logs in. But there is a program you can call from SSH that will create them (one at a time). Execute mkhomedir_helper <username> for every user (including admin) to create home shares. Make sure you do that before you try to restore any files to home folders. Otherwise, the restoration process will likely create a normal folder instead of a BTRFS sub-volume for the users, which will be problematic.
- tijgertAug 02, 2024Guide
Thanks for ripping off the band aid. It seems I am f*cked then, as in having to spend a lot of time rebuilding a perfectly good machine just because it's not smart or flexible enough to let me fix a non-problem.
It's like my car not letting me add gas to it because I ran it dry, or me not being able to crap because I ate too much. Doesn't make sense.
Thanks though.
- timhoodAug 02, 2024Star
In my case, I had two volumes and had manually moved the home folders to the second volume (using a slightly modified version of these instructions: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/ReadyNAS-428-Move-Home-Folders-to-different-volume/m-p/1833185/highlight/true#M183366. So, after re-creating the second volume, I needed to repeat my prior steps of creating the home folders on the second volume again.
- tijgertAug 03, 2024Guide
My setup is as vanilla as it gets.
1 volume, Raid5, 1 account to get in other than admin, zero apps, no time machine.
This total lockup/lockdown should not have happened.
