Inorite's avatar
Inorite
How to not lose data. Backup drive listed as dead.
I have a ReadyNas pro 4, chassy only, it's stocked with 3 WD Red Nas drives of 3TB each and I only have about 400GBs left of free space.  I just saw in the Admin suite (the webapp for the NAS) that w...
  • StephenB's avatar
    Apr 09, 2021
    WD30EFAXInorite wrote:
    but wanted to ask how to go about replacing the backup disk (disk 1) and not lose any data?
    To clarify:  There is no individual "backup disk" in your setup.  You are running XRAID (in particular RAID-5) which has single redundancy.  But there is no dedicated parity disk - instead the data and parity blocks are spread evenly across the disks.
    Your data should be ok right now, but it is certainly at risk.  I do recommend making a backup of the NAS before you go further, as a second disk issue will result in data loss.  Multiple disk failures with RAID are more common than you might think - the disks usually are installed at the same time, are identical models, in the same environment, and running under the same workload.
    Backup over the network to a USB drive in a PC is generally faster than using USB (your NAS only supports USB 2).
    Recovery isn't a difficult - you can just hot-swap disk 1 with the new (blank) disk.  It will resync, and eventually tell you it is finished (and the volume will be marked as fully redundant).  After that, you can hot-insert disk 4.  I recommend doing this with the NAS running, as the software then detects the removal and reinsertion, and doesn't have to figure out what changed while it was shut down.
    Don't get the WD30EFAas it is SMR.  Instead go with the WD30EFZX.  SMR doesn't work very well in RAID (and is particularly problematic if you are using OS 6). Generally avoid the drives current branded as "WD Reds", and get the ones branded as "Red Plus".  You can also go with a Seagate Ironwolf (they are all CMR).
    BTW, if you are running 4.2.x firmware, it is possible to convert your NAS to run OS-6.  But it does require a factory reset, so you do need a full backup.
ProSupport for Business
