jonesbf
Sep 18, 2020Aspirant
How to read data from ReadyNAS usb backup disk
I have a RNDP2000 with two 300GB drives in it. Sadly it has died. It won't power on at all. It was set to Raid1 and nightly differential backup to a 300GB USB connected SATA drive. The last email I g...
- Sep 27, 2020
If you are going to format a USB disk as NTFS, just connect it to your Windows machine and do the format there.
jonesbf
Sep 27, 2020Aspirant
I don't see NTFS as an option on the NAS interface. My NAS firmware is 4.2.31
Mauser69
Sep 27, 2020Tutor
- jonesbfSep 27, 2020Aspirant
I did this and it worked. I didn't realize the firmware version I had would recognize NTFS since it didn't offer it as a format option. Thanks!
Since the NAS is up and running on the new power supply, and I can format to something my windows machines can read in case of another failure, I'm going to consider this a success. I may install an EXT reader in Windows as well just to have that as an option.
Thanks for everyone's support.
