valerym
Nov 16, 2023Aspirant
How to Recover Data from RAID Based on Netgear ReadyNAS Duo RND2000
How to recover data from Netgear ReadyNAS Duo RND2000 which doesn’t work anymore. I have Netgear ReadyNAS Duo RND2000 with RAID1. At some point, he stopped showing signs of life. Checked the power s...
- Nov 17, 2023
Got it. I will definitely try R-Linux.
But I already managed to try Hetman RAID Recovery (https://hetmanrecovery.com/raid-data-recovery-software) in the same way. It seems to me that programs work in a similar way.
As you can see in the screenshot, the program has identified the partitions of my raid array. After scanning it, the files are available.
valerym
Nov 17, 2023Aspirant
Nov 17, 2023Guru - Experienced User
I suggested R-linux first, because it is free.
The paid version would be R-Studio, which looks comparable to the software you found.
