valerym
Nov 16, 2023Aspirant
How to Recover Data from RAID Based on Netgear ReadyNAS Duo RND2000
How to recover data from Netgear ReadyNAS Duo RND2000 which doesn’t work anymore. I have Netgear ReadyNAS Duo RND2000 with RAID1. At some point, he stopped showing signs of life. Checked the power s...
- Nov 17, 2023
Got it. I will definitely try R-Linux.
But I already managed to try Hetman RAID Recovery (https://hetmanrecovery.com/raid-data-recovery-software) in the same way. It seems to me that programs work in a similar way.
As you can see in the screenshot, the program has identified the partitions of my raid array. After scanning it, the files are available.
Nov 17, 2023Guru - Experienced User
I suggested R-linux first, because it is free.
The paid version would be R-Studio, which looks comparable to the software you found.
Sandshark
Nov 17, 2023Sensei
You say you tested the power supply? If you did so without a load on it, that's not a very good test. A failing power supply can possible deliver 5V with no load, but the voltage drops too low once a load is applied.
