Bob245's avatar
Bob245
Guide
May 08, 2019
How to shutdown my ReadyNAS Pro 4 (RNDP4000) OS6.10.0
Hello everybody.
Thanks to Guru StephenB I succesfully upgraded my ReadyNas RNDP4000 to OS6.10.0.
I am very satisfied with this update.
I activated SSH and would like to find the command to remotely turn off the NAS.
With other NAS (of other brands) I use a batch that creates the ssh connection (for example with the putty.exe)
and then I pass the poweroff command.
Below is the batch line that I use (invented password)
putty.exe [email protected] -pw ??12345678?? -m c:\poweroff\command.txt
In the file c:\poweroff\command.txt there is the simple command POWEROFF.
For the Netgear this shutdown system does not work. Can you give me advice always staying with SSH?
Thanks a lot
  • Bob245 wrote:
    putty.exe admin@192.168.10.96 -pw ??12345678?? -m c:\poweroff\command.txt
    Always use root when logging in with ssh.
    You might consider using rnutil -rn_shutdown for the NAS.  Rnutil will shut down readynasd first, and then shut down the system.
    • Bob245's avatar
      Bob245
      Guide
      Hello,
      the linux version present in my ReadyNAS OS6 is similar to other NAS that i use but I am not capable to poweroff it with batch.
      on netgear nas there is Linux NAS01 4.4.163.x86_64.1 #1 SMP Wed Mar 20 17:57:45 UTC 2019 x86_64 GNU/Linux
      on other brand there is Linux NAS00 4.14.24-qnap #1 SMP Sat Mar 23 10:47:59 CST 2019 x86_64 GNU/Linux
      Someone are capable to make a poweroff for readynas by SSH?
      Thanks
  • StephenB's avatar
    • Bob245's avatar
      Bob245
      Guide
      Hi,
      you are the best, now it work. Now the batch is this
      putty.exe [email protected] -pw ZxxxxxxxxxZ -m c:\poweroff\ReadyNAS.txt
      in the file c:\poweroff\ReadyNAS.txt there is the grace shutdown(no hypen need before rn_shutdown)
      rnutil rn_shutdown
      This upgrade os6.10.0 is fantastic: web screen very clear and simple to use, there is the hotfix automatic, iscsi work well and finally encryption (the key manage with usb key is very easy).
      Thanks a lot for you precious collaboration
      • StephenB's avatar
        Again, I recommend putty.exe root@192.168.10.96 -pw ZxxxxxxxxxZ -m c:\poweroff\ReadyNAS.txt
        Though it doesn't seem to matter for this particular command, in general you should always log in as root when you use ssh.  There are cases where running commands as admin can do damage to the OS partition (for instance, mis-setting file ownership and permissions).
ProSupport for Business
