Yoda3647
Jul 22, 2021Aspirant
How to use Streaming
Hello all can someone help/explain the Streaming function to me I must be doing something wrong. If I use my phone readycloud app go to Music or Movie and click on a file it asks me to download it......
Jul 22, 2021Guru - Experienced User
That model has a dlna server built in for compatible devices.
From a tv, its viewing the contents from the dlna server and streaming them.
Your computer is downloading them as a file as you're not viewing/accessing them using a program that can stream dlna content.
Try using windows media player to view/play the content.
Or it looks like that model has the ability to install Plex and use as a media streamer with transcoding if you'd like. (might not be the most powerful transcoder) I have plex setup on both my server and on my NAS (backup media) and it works great.
https://kb.netgear.com/25705/ReadyNAS-OS-6-Plex-Installation-Setup
- Yoda3647Jul 22, 2021Aspirant
I Did instal Plex at one time but on my TV when I clicked on Plex it would say something like no Data or Server found and when looking to share it said that to share it it cost money so I uninstalled it I can reinstall it if that is the only option, but is there no free ware that can do the same that can be loaded on and used with the NAS?? what is "Sick Chill" ??
New to the NAS is any othe apps that are on it any good??
- StephenBJul 22, 2021Guru - Experienced User
Yoda3647 - you said you were using a phone I think. In that case, you still need a DLNA player app. There are several available for both iOS and Android.
There is also a plex app - that can work w/o needing ReadyCloud.
On my phone I have VLC, do not know how to make it work phone ask to download
I use plex myself.
My understanding is that you first select the local network from menu, and that the NAS should then show up at the bottom as a DLNA or UPNP item. You'd then select it.
