Yoda3647
Jul 22, 2021Aspirant
How to use Streaming
Hello all can someone help/explain the Streaming function to me I must be doing something wrong. If I use my phone readycloud app go to Music or Movie and click on a file it asks me to download it......
Yoda3647
On my phone I have VLC, do not know how to make it work phone ask to download
Jul 22, 2021Guru - Experienced User
I use plex myself.
My understanding is that you first select the local network from menu, and that the NAS should then show up at the bottom as a DLNA or UPNP item. You'd then select it.
- Yoda3647Jul 23, 2021Aspirant
Okay I reinstalled Plex even paid for subscription. Problem On my TV (LG TV) under IN-puts I see my PC, the NAS, and the PLEX SERVER if I click on my PC and select a file it play same with the NAS, but when I click on Plex server I get No DATA????
- plemansJul 23, 2021Guru - Experienced User
does your tv have the plex app?
LG Smart TV
NOTE: Downloading and installing the Plex application is no longer required for LG Smart TV’s. The LG TV has the MediaLink service which syncs with the Plex Media Server to let you stream media content to your smart TV.I have tried this I click on "MediaLink" it say it can not find and say I need to have Plex installed on my PC and on the same router. at the bottom it say click for devices I click see my NAS click on it and nothing happens.
I guess I an just use my Roku right??????
- StephenBJul 24, 2021Guru - Experienced User
If you click on the NAS, are you able to play content on the TV?
Do you have the DLNA server enabled in Plex? I'm wondering if the PLEX SERVER you are seeing is the DLNA facility within plex, or if you are actually running a plex client built into the TV.
About how old it the TV? Have you looked for firmware updates for it?
There are a couple of settings you could adjust in the server - make sure that "secure connections" isn't set to required (preferred is fine), and perhaps also make sure the "Disable weak TLS versions" is not checked. Both of those are in the network section - the "Disable weak TLS versions" is an advanced setting. Some old clients need those settings.
- Yoda3647Jul 24, 2021Aspirant
If it help with making this work: Input List on TVWhen I click on Plex ServerCan Play Straight from NASMedia Link after it loadsClick on Device Selection after picking nothing happens
