edalquist
Dec 22, 2011Apprentice
HOWTO: Disable WD IDLE3 via ReadyNAS
I did this on my ReadyNAS Ultra 4. I installed the RootSSH Access addon to get shell access and got the idle3-tools download link from http://idle3-tools.sourceforge.net/ # Install packages need...
swalter0306
Jul 12, 2012Aspirant
Edalquist,
you truly made my day :-]]]
I just tried this on a Duo v2 and it simply worked like a charm. I got two WD20EARX disks inside the unit, running for four months now - and stumbled across the LCC issue just two weeks ago. I realized that one of the disks had already reached 100K, so I was desperately seeking for a way to get rid of this.
I had no way of finding a current desktop machine that I could hook up the drives to, so this was my last hope.
Thank you, thank you, THANK YOU!!!
