edalquist
Dec 22, 2011Apprentice
HOWTO: Disable WD IDLE3 via ReadyNAS
I did this on my ReadyNAS Ultra 4. I installed the RootSSH Access addon to get shell access and got the idle3-tools download link from http://idle3-tools.sourceforge.net/ # Install packages need...
tiranor
Sep 11, 2012Aspirant
When i looked at this problem on WD forums, disabling the parking is heavily discouraged, as many people reported bad behavior of the disk. The recommended value is 254, it's as if disabled (i don't get any LCC, as i disabled the disks' shutdown).
