edalquist
Dec 22, 2011Apprentice
HOWTO: Disable WD IDLE3 via ReadyNAS
I did this on my ReadyNAS Ultra 4. I installed the RootSSH Access addon to get shell access and got the idle3-tools download link from http://idle3-tools.sourceforge.net/ # Install packages need...
mdgm-ntgr
Sep 15, 2012NETGEAR Employee Retired
Peekay the instructions are for x86 (i.e. NVX/Ultra/Pro) not for Sparc e.g. your NV+ (v1). Don't think the source code would be designed to run on Sparc anyway so even if you could get it to compile I wouldn't trust it.
Edit: A user above reported them working on the Duo/NV+ v2 (ARM) but that's very different hardware with a different OS.
