edalquist
Dec 22, 2011Apprentice
HOWTO: Disable WD IDLE3 via ReadyNAS
I did this on my ReadyNAS Ultra 4. I installed the RootSSH Access addon to get shell access and got the idle3-tools download link from http://idle3-tools.sourceforge.net/ # Install packages need...
mdgm-ntgr
Sep 15, 2012NETGEAR Employee Retired
Did you force apt-get to install the packages even though they have unmet dependencies. If not you should be fine.
However if you want to restore full software support you should backup your data and do a factory reset.
The new WD Red disks already have the appropriate WDIDLE3 setting. Unfortunately only the WD10EFRX is on the compatibility list for your NV+ (v1) at this time.
