edalquist
Dec 22, 2011Apprentice
HOWTO: Disable WD IDLE3 via ReadyNAS
I did this on my ReadyNAS Ultra 4. I installed the RootSSH Access addon to get shell access and got the idle3-tools download link from http://idle3-tools.sourceforge.net/ # Install packages need...
Ney
Nov 22, 2012Aspirant
I just wanted to say thank you for this guide. My LCC count had gotten over 20k in less than 3 months =O So set it to 254 on all disks and hope it helps :)
Do you people know wether enable HDD spindown in the power menu is adviced with WD green disks or should i disable it and let the Greens do their thing?
