edalquist
Dec 22, 2011Apprentice
HOWTO: Disable WD IDLE3 via ReadyNAS
I did this on my ReadyNAS Ultra 4. I installed the RootSSH Access addon to get shell access and got the idle3-tools download link from http://idle3-tools.sourceforge.net/ # Install packages need...
mgbenson
Jan 13, 2013Aspirant
Is anyone able to confirm if this method work/should be tried on an NV+v2?
I've got 2 x WD20EARX drives installed (both '-008FB0' with LCC ~235,000), and have just added a third ('-00PASB0' which is claiming it failed during restriping) before I stumbled across this thread and the advice to not use the WD green.... :(
