petas_70
Apr 30, 2009Aspirant
HP Officejet 8500 "network filling" ready NAS Duo problem.
Hello, I got the above OfficeJet 8500, everything ...accept the "network filling" or scanning to the network folder works fine. Every time, I am trying to scan to network folder the printer creates ...
beurnz
Aug 09, 2010Aspirant
OK,
#1 - Note to PapaBear: The printer is connected wirelessly to the network. Also, as with most others experiencing this issue, I have tried the printer document filing to a Windows share on my PC and it works fine.
#2 - I was contacted by NETGEAR support which directed me to the following thread http://h30434.www3.hp.com/t5/Scanning-faxing-and-copying/OfficeJet-8500-Wireless-scan-to-folder-on-an-Readynas-NV/td-p/60403/page/2
and the following addon http://www.readynas.com/download/addons/4.1/Toggle_OfficeJet_Scan_Support_1.0.bin
I diligently read the thread and first created a new share with the name HP-Documents. Then I tried applying the addon but I get the following message "Invalid checksum detected in the update file. Update aborted".
I currently have a ReadyNAS Duo with DAIDiator 4.1.6[1.00a043]
When try adding the addon, I first get this, which seems OK:
"The firmware update or Add-on image is valid. Click Perform System Update if you wish to install the
image now.
Version: 1.0
Date: Thu Jan 7 14:09:26 2010
Description:
Awaiting an answer from NETGEAR support for case # 12814629
image now.
Version: 1.0
Description:
