Bran_Scone
Jan 11, 2020Aspirant
I can update Firmware from 6.7.4 asf the AntiVirus is out of date and wont download.
My ReadyNAS is currently runnig on 6.7.4 and i cant seem to update. I also have an issue with the Antivirus as its out of date and wont update. I hagve an error on the log also ; Volume: System v...
Bran_Scone
Jan 12, 2020Aspirant
ReadyNAS OS 6 104
I think as I cant get access today as its failing to start-up, stuck on the;
Booting...
from the LED display. Switch it off and on a couple of time no improvement.
Bran_Scone
sorry should have also added no apps installed.
- StephenBJan 12, 2020Guru - Experienced User
Over time, the Antivirus service has taken more and more memory, and the RN100 series no longer has the ability to run it. It was actually removed from the RN100s in 6.9.x firmware - but your firmware is very old, and of course it wasn't removed.
The full root partition likely is the result of the AV service becoming unstable - we've seen that in many systems here.
As JohnCM_S says, paid Netgear support can take care of this for you. If you are ok with ssh, we can point you to instructions. But if you aren't familar with it already, you are better off using support.
