Peter_Zulof
Mar 22, 2016Guide
Import users from active directory
HI All, I have a problem importing users from active directory, despite that the operation completed successfully but i cant found users after authentication succeed. It was working fine, then i...
sviiimue
Apr 11, 2016Aspirant
thank you Peter_Zulof
i tested a second unit, factory reseted and it doesn't work either.
Then i tested it with a second, test lab, domain controller 2012R2 and it worked neither.
The problems with the netgear nas drive me crazy and I probably will sooner or later exchange and sell off all netgear devices.
edit: Firmware on both 6.4.2.
Peter_Zulof
Apr 11, 2016Guide
The same for me, i am taking backup right now then i will restore it to defualt and will try again.
if didn't work i will send it back to the seller.
- sviiimueApr 11, 2016Aspirant
tested also downgrading to 6.4.0 and upgrading to 6.5.0-T338
don't work. thats bull#! @netgear
hi Peter_Zulof
i have done the following workaround:
-Join the NAS to the Domain
-setup the share permissions like in this articel: http://kb.netgear.com/app/answers/detail/a_id/7066/~/readynas-os-6%3A-setting-active-directory-folder-permissions
(i removed everyone, guest etc. completly and added the domain users, domain admins ...)
regards
- Peter_ZulofApr 12, 2016Guide
Thank you sviiimue , i will try it after finishing backup, its taking long time because i am doing it through network
- mdgm-ntgrApr 12, 2016NETGEAR Employee Retired
Using that article is what we recommend for configuring permissions.
If you have trouble joining the domain you should contact support to do the troubleshooting for that. Support won't be able to help with doing it on a beta firmware release unless they suggested trying that in a support case, but they would be able to help with doing it on 6.4.2.
In 6.5.0 we have updated samba to the latest samba series (4.4) from the 4.2 series.If your support has expired then support would ask you to purchase additional support. Note that if it's a business class product purchased on/after June 1, 2014 it may have lifetime chat support.
It's important to make sure the NAS is using the same time server as the Domain Controller. If the time is not in sync then joining the domain will fail.
Joining the domain should work smoothly, but if it doesn't it may require advanced troubleshooting, reviewing logs and using e.g. Teamviewer to have a look at your server and figure out why the domain join is failing. For initial setup the 90 days of support from the date of purchase should be more than enough time to resolve any issues with this.If you have trouble joining a domain and don't know why and don't wish to purchase support you could backup your data and do a factory default (wipes all data, settings, everything) if you didn't do one recently and try again.
We can also review your logs, but it may not be something we can easily resolve through community support.
- mdgm-ntgrApr 14, 2016NETGEAR Employee Retired
Do you have any further questions?
- Peter_ZulofApr 14, 2016Guide
No but the problem still exist.
HI, After restoring readynas 314 to factory setting its worked fine and imported users from active directory
- mdgm-ntgrApr 30, 2016NETGEAR Employee Retired
Has it been working fine these past few weeks?
