jpass022
Jul 10, 2016Luminary
Importing EXPORTed volumes for Readynas 516s with OS 6.5.1
Looking for help on Importing my EXPORTed volumes? I've tried all the suggestions I've read about on here. I even looked in the manual and found nothing... The only thing I haven't tried is reinstall...
- Jul 19, 2016
Called Netgear support to do my "Cold Import" on my "Export"ed volume. Only took them lees than 30 seconds to tweak whatever setting to fix. It didn't involve reinstalling the OS as someone else had alluded to. I asked the person to explain what he did, but they only told me that it wasn't a straightforward fix and left it at that. So sorry I can't share how to fix this problem if anyone else ever gets in this similar predicament... I recommend not using the export feature until someone at Netgear decides to expalin it better than just the pop-up when you click on the EXPORT feature....
Jul 10, 2016Guru - Experienced User
You shouldn't have exported the volumes. All you needed to do was power down both systems and swap the drives.
Did you purchase between 1 June 2014 and 31 May 2016? If so, you have lifetime chat support - I suggest that you use it.
jpass022
Thanks, for the advice, but not helpful at this point, I need going forward options??? I purchased in April 2013....
Hopefully someone will have the answer here? I see it will cost me $380 just to talk to somone....
- StephenBJul 11, 2016Guru - Experienced User
Per-incident support is around $75 in the US, not $380. My only advice is to use support.
https://community.netgear.com/t5/Using-your-ReadyNAS/how-can-I-bring-back-exported-disk/td-p/1015184 was a similar issue.
- jpass022Jul 11, 2016Luminary
StephenB,
Thanks for ths information. I couldn't find the per incident rate? Only the $380 per year rate...
I tried all the ideas in that post... :smileyhappy:
