jpass022
Jul 10, 2016Luminary
Importing EXPORTed volumes for Readynas 516s with OS 6.5.1
Looking for help on Importing my EXPORTed volumes? I've tried all the suggestions I've read about on here. I even looked in the manual and found nothing... The only thing I haven't tried is reinstall...
- Jul 19, 2016
Called Netgear support to do my "Cold Import" on my "Export"ed volume. Only took them lees than 30 seconds to tweak whatever setting to fix. It didn't involve reinstalling the OS as someone else had alluded to. I asked the person to explain what he did, but they only told me that it wasn't a straightforward fix and left it at that. So sorry I can't share how to fix this problem if anyone else ever gets in this similar predicament... I recommend not using the export feature until someone at Netgear decides to expalin it better than just the pop-up when you click on the EXPORT feature....
Jul 11, 2016Guru - Experienced User
jpass022 wrote:
Thanks for ths information. I couldn't find the per incident rate? Only the $380 per year rate...
You'll need to call and ask.
jpass022
Jul 19, 2016Luminary
