wasedky
Oct 21, 2016Tutor
Incomplete backups after recent firmware update (ReadyNas NV+) 4.1.15
Hi I had the system run perfectly with no issues until it informed me of the 4.1.15 update. I went ahead with the update and now backups are incomplete. It stops around folders starting with M. To ma...
- Oct 24, 2016
Does it behave differently if you select Remote: Windows/NAS (Timestamp) ?
Oct 21, 2016Guru - Experienced User
Maybe try resetting owners/permissions for the share before you try downgrading (using whatever options are appropriate for you)
You can downgrade, I don't recall off-hand where the old version is saved in the logs. You could try downloading the log zip, and searching them.
- wasedkyOct 21, 2016Tutor
I couldn't find that screen. I assumed it would be under security, but i looked in all of them. Where would it be?
Nevermind about the previous comment. I found it and it is exactly as your screenshot.
After checking the log I found that the system seems to have worked for a while after the upgrade date that is specified in the logs.
What else could it be? I'd like to avoid having to write my own script to do the backup.
- StephenBOct 21, 2016Guru - Experienced User
Try resetting the owners/permissions.
Perhaps also give us the screenshots of the backup job configuration (you can color over any confidential information).
- wasedkyOct 24, 2016Tutor
The "Test Connection" succeeds and the backup partially works. It just stops at some point (always the same point) and it does not report a failure.
