wasedky
Oct 21, 2016Tutor
Incomplete backups after recent firmware update (ReadyNas NV+) 4.1.15
Hi I had the system run perfectly with no issues until it informed me of the 4.1.15 update. I went ahead with the update and now backups are incomplete. It stops around folders starting with M. To ma...
- Oct 24, 2016
Does it behave differently if you select Remote: Windows/NAS (Timestamp) ?
Oct 21, 2016Guru - Experienced User
Maybe try resetting owners/permissions for the share before you try downgrading (using whatever options are appropriate for you)
You can downgrade, I don't recall off-hand where the old version is saved in the logs. You could try downloading the log zip, and searching them.
wasedky
Oct 21, 2016Tutor
I couldn't find that screen. I assumed it would be under security, but i looked in all of them. Where would it be?
