wasedky
Oct 21, 2016Tutor
Incomplete backups after recent firmware update (ReadyNas NV+) 4.1.15
Hi I had the system run perfectly with no issues until it informed me of the 4.1.15 update. I went ahead with the update and now backups are incomplete. It stops around folders starting with M. To ma...
- Oct 24, 2016
Does it behave differently if you select Remote: Windows/NAS (Timestamp) ?
wasedky
Oct 21, 2016Tutor
Nevermind about the previous comment. I found it and it is exactly as your screenshot.
After checking the log I found that the system seems to have worked for a while after the upgrade date that is specified in the logs.
What else could it be? I'd like to avoid having to write my own script to do the backup.
Oct 21, 2016Guru - Experienced User
Try resetting the owners/permissions.
Perhaps also give us the screenshots of the backup job configuration (you can color over any confidential information).
- wasedkyOct 24, 2016Tutor
The "Test Connection" succeeds and the backup partially works. It just stops at some point (always the same point) and it does not report a failure.
