wasedky
Oct 21, 2016Tutor
Incomplete backups after recent firmware update (ReadyNas NV+) 4.1.15
Hi I had the system run perfectly with no issues until it informed me of the 4.1.15 update. I went ahead with the update and now backups are incomplete. It stops around folders starting with M. To ma...
- Oct 24, 2016
Does it behave differently if you select Remote: Windows/NAS (Timestamp) ?
wasedky
Oct 24, 2016Tutor
The "Test Connection" succeeds and the backup partially works. It just stops at some point (always the same point) and it does not report a failure.
